查看: 5541|回復: 14
約翰霍普金斯最新癌症研究與漢唐中醫 倪海廈的評論
發表於 2012-1-23 19:42:04 | 顯示全部樓層 |閱讀模式
約翰霍普金斯最新癌症研究
以下是約翰霍普金斯最新之癌症研究, 十分有閱讀價值.  祝身體健康  長命百歲.
The following is the cancer research from John Hopkins, it is value to read. Wish you good health and long-live.
1. Every person has cancer cells in the body. These cancer cells do not show up in the standard tests until they have multiplied to a few billion. When doctors tell cancer patients that there are no more cancer cells in their bodies after treatment, it just means the tests are unable to detect the cancer cells because they have not reached the detectable size.
每一個人身上都帶有癌細胞,除非癌細胞擴增至幾十億個數量時癌細胞是無法在一般檢查時被檢查出來的。所以每當病患治療到一個階段後醫生會告訴病患其體內已無癌細胞時,醫生所指的是其體內癌細胞數量已縮小到儀器無法偵測出來的數量。
2. Cancer cells occur between 6 to more than 10 times in a persons lifetime.
在每個人的生命期裡,癌細胞都會出現6至10次。
3. When the persons immune system is strong the cancer cells will be destroyed and prevented from multiplying and forming tumors.
當人體免疫系統強時,癌細胞是會被摧滅的,同時免疫系統強是能抑制腫瘤形成及擴增。
4. When a person has cancer it indicates the person has multiple nutritional deficiencies. These could be due to genetic, environmental, food and lifestyle factors.
當人被發現有癌症時,它意謂這個病患是有大量營養缺乏;這可能是由於基因、環境、食物及生活方式等因素造成的。
5. To overcome the multiple nutritional deficiencies, changing diet and including supplements will strengthen the immune system.
如何克服營養缺乏,那就是要改變飲食及多進用增強免疫系統之食物
6. Chemotherapy involves poisoning the rapidly-growing cancer cells and also destroys rapidly-growing healthy cells in the bone marrow, gastro-intestinal tract etc, and can cause organ damage, like liver, kidneys, heart, lungs etc.
化療不祇能毒殺快速增長之癌細胞,亦會一併消滅骨髓及胃腸道內之健康細胞,同時造成器官衰竭;如肝臟、腎臟、心臟及肺臟等等。
7. Radiation while destroying cancer cells also burns, scars and damages healthy cells, tissues and organs.
放射治療在摧毀癌細胞時,亦會灼傷健康細胞、組織及器官
8. Initial treatment with chemotherapy and radiation will often reduce tumor size. However prolonged use of chemotherapy and radiation do not result in more tumor destruction.
初期化療及放射線治療是很容易將腫瘤面積縮小到某一程度,然再延長上述療法並不能造成腫瘤完全消除。
9 When the body has too much toxic burden from chemotherapy and radiation the immune system is either compromised or destroyed, hence the person can succumb to various kinds of infections and complications.
化療及放射線治療會讓體內存有大量毒素而危及或摧毀免疫系統,因而導致病患易於感染及病發症
10. Chemotherapy and radiation can cause cancer cells to mutate and become resistant and difficult to destroy. Surgery can also cause cancer cells to spread to other sites.
化療及放射線治療會造成病患癌細胞突變及產生抗體而變得難以摧毀,而手術則易使癌細胞擴散至其它部位(其實是從切片後就已經開始擴散了。)
11. An effective way to battle cancer is to starve the cancer cells by not feeding it with the foods it needs to multiply.
一個有效的擊潰癌細胞之方式是不供給癌細胞繁殖所需之食物,即是餓死癌細胞
CANCER CELLS FEED ON:
癌細胞以何為食物:
a. Sugar is a cancer-feeder. By cutting off sugar it cuts off one important food supply to the cancer cells. Sugar substitutes like NutraSweet, Equal,Spoonful, etc are made with Aspartame and it is harmful. A better natural substitute would be Manuka honey or molasses but only in very small amounts. Table salt has a chemical added to make it white in color. Better alternative is Braggs aminos or sea salt.
糖是癌的食物,若不食糖即刪除癌細胞很重要的一項食物供給。代糖如Nutra sweet, Equal spoonful等均是由Aspartame 組合而成的,是有害的。較好之天然代糖是 Manuka糖漿或Molasses糖蜜,但祇能取用少許。食鹽為使顏色變白而滲有化學添加物,較妥之選擇是海鹽。
b. Milk causes the body to produce mucus, especially in the gastro-intestinal tract. Cancer feeds on mucus. By cutting off milk and substituting with unsweetened soya milk cancer cells are being starved.
牛奶會使人體產生黏液,尤其是在胃腸道內,而黏液正是癌症之食物。因而阻絕牛奶及採用不甜之豆漿作替代,癌症就會在無食物情況下萎縮的。
c. Cancer cells thrive in an acid environment. A meat-based diet is acidic and it is best to eat fish, and a little chicken rather than beef or pork. Meat also contains livestock antibiotics, growth hormones and parasites, which are all harmful, especially to people with cancer.
癌細胞是在酸性環境中繁衍的,以肉為基本飲食的體質是酸性的,因而食用魚類及少量雞肉是較食用牛、豬為妥的。且肉品均含有家畜抗生素、生長賀爾蒙及寄生蟲等,而這些均是對人體的有害物質,尤其是對癌症病患。
d. A diet made of 80% fresh vegetables and juice, whole grains,seeds, nuts and a little fruits help put the body into an alkaline environment.. About 20% can be from cooked food including beans. Fresh vegetable juices provide live enzymes that are easily absorbed and reach down to cellular levels within 15 minutes to nourish and enhance growth of healthy cells. To obtain live enzymes for building healthy cells try and drink fresh vegetable juice (most vegetables including bean sprouts)and eat some raw vegetables 2 or 3 times a day. Enzymes are destroyed at temperatures of 104 degrees F (40 degrees C).
以80%新鮮蔬菜及青菜汁之飲食;含全穀類、種子、堅果及少量的水果是有益於體質轉變為鹼性的,剩餘20%可進食煮熟的豆類。新鮮蔬菜汁可提供活性酵素,活性酵素極易在15分鐘內被細胞組織吸收進而滋養增強健康細胞,為取得活性酵素強壯健康細胞應多飲用新鮮果菜汁(多樣蔬菜含豆芽),同時每天進食生青菜(未煮過之)兩至三次,按活性酵素在40度C時會被摧毀。
e. Avoid coffee, tea, and chocolate, which have high caffeine.Green tea is a better alternative and has cancer-fighting properties. Water-best to drink purified water, or filtered, to avoid known toxins and heavy metals in tap water Distilled water is acidic, avoid it.
飲料必須避免飲用咖啡、茶、巧克力因上述飲料含咖啡因,綠茶是較佳之選擇因為其有抗癌特性。而平常應飲用淨化水或過濾水,然應避免飲用有毒的或重金屬的水。蒸餾水是酸性的不要喝
12. Meat protein is difficult to digest and requires a lot of digestive enzymes. Undigested meat remaining in the intestines become putrified and leads to more toxic buildup.
肉類的蛋白質是不易消化的,因為肉類的蛋白質需要大量消化酵素消化,未消化的肉質會留殘在腸內淨化,而引發有毒物質形成。
13. Cancer cell walls have a tough protein covering. By refraining from or eating less meat it frees more enzymes to attack the protein walls of cancer cells and allows the bodys killer cells to destroy the cancer cells.
癌細胞壁有很硬之蛋白質包裹,因而節制食用肉類可讓多出之酵素去攻擊癌細胞之蛋白質,而體內殺手細胞則有空間摧毀癌細胞
14. Some supplements build up the immune system (IP6, Flor-ssence,Essiac, anti-oxidants, vitamins, minerals, EFAs etc.) to enable the bodys own killer cells to destroy cancer cells. Other supplements like vitamin E are known to cause apoptosis, or programmed cell death, the bodys normal method of disposing of damaged, unwanted, or unneeded cells.
部份營養品是能增強免疫系統(如抗氧化劑、維他命、礦物質等等)去驅使自體殺手細胞去摧毀癌細胞,其他營養品如維他命E會使細胞萎縮,或漸使細胞死亡,而非原體內一般處置損壞、無用及不需要細胞之模式。(這段有問題,我們都需要維他命,但是不是去吃西藥廠生產的片劑,要從天然食物中取得才對免疫系統有利。)
15. Cancer is a disease of the mind, body, and spirit. A proactive and positive spirit will help the cancer warrior be a survivor Anger, unforgiveness and bitterness put the body into a stressful and acidic environment. Learn to have a loving and forgiving spirit. Learn to relax and enjoy life.
癌症是一種心態、肉體和心靈上之疾病,因而能有前衛及積極的心靈是可造就癌症戰士變為勝利天使,怨尤和苦痛會讓體質變為緊張及酸性,所以必須學習愛與寬恕,同時學習放鬆及愛習惜生命
16. Cancer cells cannot thrive in an oxygenated environment. Exercising daily, and deep breathing help to get more oxygen down to the cellular level. Oxygen therapy is another means employed to destroy cancer cells
癌細胞是無法在充滿氧氣的環境中繁衍,所以每日必須運動,同時多作深呼吸以利氧進入細胞層,按氧氣療法是另一種擊潰癌細胞之工具。
(PLEASE FORWARD IT TO PEOPLE YOU CARE ABOUT)
CANCER UPDATE FROM JOHN HOPKINS HOSPITAL , U S - PLEASE READ
1. No plastic containers in micro.
不要將塑膠盒放入微波爐加熱
戴奧辛之化學物質會導致癌症,尤其是乳癌。按戴奧辛對體內細胞具很高之毒性,因而千萬別將裝有水之塑膠罐放入冰箱,因為它亦會將戴奧辛釋出。
2. No water bottles in freezer.
不要將塑膠水瓶放入冷藏室
3. No plastic wrap in microwave.
不要將塑膠袋放入微波爐加熱
Johns Hopkins has recently sent this out in its newsletters. This information is being circulated at Walter Reed Army Medical Center as well.
jane3317 + 10
 樓主| 發表於 2012-1-23 19:42:29 | 顯示全部樓層
本文章最後由 陳青 於 2012-1-23 19:49 編輯
約翰霍普金斯已將這篇研究報告用新聞稿方式發佈,同時Walter Reed 陸軍醫學中心亦將這篇報告傳播
Dioxin chemicals causes cancer, especially breast cancer.
Dioxins are highly poisonous to the cells of our bodies.
Dont freeze your plastic bottles with water in them as this releases dioxins from the plastic.
Recently, Dr.. Edward Fujimoto, Wellness Program Manager at Castle Hospital , was on a TV program to explain this health hazard. He talked about dioxins and how bad they are for us. He said that we should not be heating our food in the microwave using plastic containers.
前不久Dr. Edward Fujimoto在電視節目中談到健康之風險,他就強調戴奧辛對健康是多麼有害,因而請千萬不要用塑膠容器放入微波爐加熱食物。
This especially applies to foods that contain fat. He said that the combination of fat, high heat, and plastics releases dioxin into the food and ultimately into the cells of the body. Instead, he recommends using glass, such as Corning Ware, Pyrex or ceramic containers for heating food. You get the same results, only without the dioxin. So such things as TV dinners, instant ramen and soups, etc., should be removed from the container and heated in something else.
這尤其是指含有脂肪之食物,當脂肪與高溫與塑膠結合時,塑膠即會釋放出戴奧辛並進入食物中,最終就進入體內之細胞。因而他建議使用玻璃器皿作為加熱食物用,因為它一樣可使食物變熱,然卻少了戴奧辛。
Paper isnt bad but you dont know what is in the paper. Its just safer to use tempered glass, Corning Ware, etc. He reminded us that a while ago some of the fast food restaurants moved away from the foam containers to paper. The dioxin problem is one of the reasons.
紙是不錯的容器,然你無法瞭解紙裡到底含有什麼物質,因而較安全之容器是冶煉過的玻璃器皿,如康寧器皿等等。他提醒為何前不久速食店將泡沫塑料容器改為紙容器,其中戴奧辛就是問題之一
Also, he pointed out that plastic wrap, such as Saran, is just as dangerous when placed over foods to be cooked in the microwave. As the food is nuked, the high heat causes poisonous toxins to actually melt out of the plastic wrap and drip into the food. Cover food with a paper towel instead.
同時他亦指出塑膠袋;如Saran耐熱塑膠袋用於包裝食物,在微波爐加熱時亦是非常危險的,因為當食物用微波爐加熱時,高溫會讓毒素由塑膠袋溶解出來進入食物內,所以應用紙包裹食物作替代。
漢唐中醫 倪海廈評論
     讀者看完這篇研究後,是否覺得很眼熟呢,因為多年以來,我ㄧ直就在說這些理論,而今美國最有名的癌症研究中心之一的約翰霍普金斯,也提出相同的看法,其中有關治療癌症最有效的方法就是阻絕食物供應癌腫瘤,這也是我ㄧ直在強調的各種維他命不能吃的原因,這篇研究報告美中不足的就是他們沒有提到癌腫瘤需要水的問題,這才是治癌致勝的地方,癌腫瘤跟人一樣需要水跟食物,我們可以七天不吃食物也不會死亡,但是每天都必須喝水,如何阻絕水來供應癌腫瘤,這才是治療癌症的關鍵地方,幾乎所有的癌症病人都可以看到有出現積水現象,如肝癌後期可以看到病人腹水嚴重,這就是說明癌症在製造一個水的環境,隨時可以供應它們有水喝,不慮匱乏,只要有水,它們就可以存活,所以光是知道阻斷食物的供應是不足以治療癌症的,我ㄧ直在說現在的標靶藥物就是想辦法在阻斷食物的供應,可是結果還是無效,其原因就是無法阻止水的供應,在此我不能詳細說明給大家聽,因為盜版的人實在太多,這些不知道尊重智慧財產權的人,造成大家都無法分享這些最好的知識。
    六年前一位42歲的獸醫來自賓州,他得到腦瘤,在約翰霍普金斯醫學中心開刀治療,開完刀後二個月腫瘤又再生出來而且更大,於是再開第二次刀,結果還是一樣再生出來,而且比以前更大些,於是該院中的一名護士將我的名片拿給他,告訴他你可能需要到佛州來找這位中醫治療,於是他來到桃花島,經過約九個月的中藥湯劑治療,之後就完全無法查出腦部有腫瘤了。此人非常之高大,初診來的時候一邊身體癱瘓而無法控制,坐著輪椅進來診間,服藥二個月後就可以很快速的走進診療室,光是生附我開給他的劑量每副就達到七錢,所以劑量很重要,不敢使用生附子的中醫,是無法治療癌症的。
    附註 : 這篇研究於2009年已經被約翰霍普金斯醫學中心否定了,我相信這是因為該中心無法抵抗來自外在利益團體的壓力而做的否定,因為其中所有的牛奶商,甜食商,飲料商等,全面的都被否定,這必然引起是一場風暴,我想這就是它被否定的真正原因。我個人認為它是正確的,因為從臨床上看就是這樣表現的,從治療各種不同癌症的經驗中可以看出是正確的說法。只是西醫著重在飲食上面,中醫不但要癌症病人注意飲食,還要注意病人身體內水的平衡,西醫都是驗血報告,而從不做驗水報告。有人認為是騙局,這是本身利益受到影響,我認為是正確的。
漢唐中醫 倪海廈謹記於佛州2011年03月06日
347
發表於 2012-1-24 07:57:07 | 顯示全部樓層
隨時都會找尋你的PO文 為了健康就必須跟隨
"癌細胞是在酸性環境中繁衍的"
我於數年前閱讀一本名為"PH "為美國名醫撰寫 內容與此理論不謀而合
當然保持體質偏微鹼的重要性是人所週知 不但可保持身體健康 而且能避免病菌或病媒在裡成長 但是酸性鹼性的食物 人們多少在認知上與實際有所不符 還望專家就此專題給予正確答案 讓我們遵循          功德無量
 樓主| 發表於 2012-1-24 08:29:08 | 顯示全部樓層
"癌細胞是在酸性環境中繁衍的"
我於數年前閱讀一本名為"H "為美國名醫撰寫 內容與此理論不謀而合
當然保持體質偏微鹼的重要性是人所週知 不但可保持身體健康 而且能避免 ...
ausfarmer 發表於 2012-1-24 07:57
歡迎一起研究,找到健康之道~~~~~~
我這一生,喜歡鑽研的事物很多,其中一項,就是如何在平日飲食中得到健康,行動如何生龍活虎,筋骨如何堅如鐵石,此生樂趣多多,說之不盡。
22
發表於 2012-1-24 10:43:36 | 顯示全部樓層
" 不要用塑膠容器放入微波爐加熱食物 "
政府應去測試
如果屬實
該禁止便利店販售塑膠盒裝的熱食
便利店大多用微波爐加熱
參與人數 1威望 +3 收起 理由
陳青 + 3
辛苦賺生活 生活要快樂
 樓主| 發表於 2012-1-24 10:47:40 | 顯示全部樓層
政府應去測試
如果屬實
該禁止便利店販售塑膠盒裝的熱食
便利店大多用微波爐加熱
MASA50 發表於 2012-1-24 10:43
是的,政府應該自動把關,維護國民健康,責無旁貸。
295
發表於 2012-1-24 13:44:01 | 顯示全部樓層
之前看到老前輩的po文,說癌症是人體排毒的代償機制,我才恍然大悟。
人體是極精妙的,這上帝的成品說它有瑕疵,發燒、打噴嚏、疼痛是身體故障,故需用葯排除,是非常不可思議的。
同樣,腫瘤、癌細胞是身體故障也是令人不解。
同一現象,不同解釋方法,造成解決與預防天差地遠的不同。
如果不排毒乾淨,只把心思放在排除癌細胞,預後如何大家都很清楚。
本文在現象上比傳統西醫更清楚見到癌症的成因助緣,但對癌細胞的看法跟傳統西醫一致,認為是惡的,是需排除的。
如果知道癌細胞是排毒的代償機制,根本就無需理會癌症了。發現癌症,很簡單,生活習慣改成會養氣養血的習慣,多喝水排毒,少出惡念產生毒素........,不久一定會看到癌細胞變少,因為身體健康後排毒機制漸漸恢復正常,自然不用找癌細胞代償了。
295
發表於 2012-1-24 14:29:27 | 顯示全部樓層
常常我只用簡單的文字說明,很多人會看不懂,而不願相信認同。
關於本文視癌細胞為惡的文字如下:
1、當人體免疫系統強時,癌細胞是會被摧滅的,同時免疫系統強是能抑制腫瘤形成及擴增。
**如果不視之為惡,說法上會說身體健康免疫系統強,故無需大量癌細胞的協同作用,故現象上的觀察可解釋為可抑制腫瘤形成及擴增。
2、一個有效的擊潰癌細胞之方式是不供給癌細胞繁殖所需之食物,即是餓死癌細胞
**這句話極明顯示之為惡,不視之為惡,說法上不用擊潰,而是癌細胞被身體回收無需拿出來作用
3、糖是癌的食物,若不食糖即刪除癌細胞很重要的一項食物供給。代糖如Nutra sweet, Equal spoonful等均是由Aspartame 組合而成的,是有害的。較好之天然代糖是 Manuka糖漿或Molasses糖蜜,但祇能取用少許。食鹽為使顏色變白而滲有化學添加物,較妥之選擇是海鹽。
牛奶..........
肉、魚.........
**這亦復是視之為惡,反之說法為:這些食物本身會產生需排除的廢物,因身體排除的機制不良(身體不健康),故需代償機制加入作用以協助排除,以免身體累積過多無法負荷而崩潰。
4、癌症是一種心態、肉體和心靈上之疾病,因而能有前衛及積極的心靈是可造就癌症戰士變為勝利天使,怨尤和苦痛會讓體質變為緊張及酸性,所以必須學習愛與寬恕,同時學習放鬆及愛習惜生命
**這段說的極好,但把協助身體的機制-癌細胞視為敵人而不愛不寬恕,並不是一件好事,既然要愛,就需視萬事萬物為一體,視萬事萬物與自己同一無二,不然這分別心就讓這段話給破功了--小心自己的意識型態,左右自己想法行動,造成自己幸與不幸!
 樓主| 發表於 2012-1-24 18:08:58 | 顯示全部樓層
發現癌症,很簡單,生活習慣改成會養氣養血的習慣,多喝水排毒,少出惡念產生毒素........,不久一定會看到癌細胞變少,因為身體健康後排毒機制漸漸恢復正常,自然不用找癌細胞代償了。indu 發表於 2012-1-24 13:44
這就是重點,讚~~~~~
31
發表於 2012-1-24 21:42:38 | 顯示全部樓層
陳青 發表於 2012-1-24 10:47
難道你是白痴嗎?
政府只讓你吃化學的藥!
自然醫學的營養食品不准郵購!
政府只會抽重稅,再毒死台灣人,
你還相信!死的快!
GMT+8, 2026-10-21 05:29 , Processed in 0.059404 second(s), 20 queries .
