查看: 4352|回復: 1
微波爐不得用塑膠容器
發表於 2006-8-11 07:32:27 | 顯示全部樓層 |閱讀模式
分享:
約翰霍浦金斯醫院發怖的癌症訊息
1. No plastic containers in microwave.
  微波爐不得用塑膠容器
2. No water bottles in freezer.
冷凍室內不得放水瓶
3. No plastic wrap in microwave.
微波爐內不得用塑料包覆膜
3. Johns Hopkins has recently sent this out in its Newsletters. This
information is being circulated at Walter Reed Army Medical Center.
約翰霍浦金斯醫院最近在其新聞發怖佈稿中透露了上述訊息。此訊息也正在華特里德陸軍醫學中心流傳著。
4.Dioxin chemicals causes cancer, especially breast cancer.
戴奧辛化學品致癌,尤其是乳腺癌。
5.Dioxins are highly poisonous to the cells of our bodies. Dont freeze your
plastic bottles with water in them as this releases dioxins from the plastic.
戴奧辛對人體細胞毒性極高。不要將你的裝了水的塑膠瓶予以冷凍,因為如此則塑膠會釋出戴奧辛。
6.Recently, Dr. Edward Fujimoto, Wellness Program Manager at Castle Hospital,
was on a TV program to explain this health hazard. He talked about dioxins
and how bad they are for us.
卡索醫院保健計畫的主持人藤本愛德華醫生,最近上電視解釋此項對健康之危害。他談到了戴奧辛,以及其為何對我們有危害。
7.He said that we should not be heating our food in the microwave using
plastic containers. This applies to foods that contain fat. He said that the
combination of fat, high heat, and plastics releases dioxin into the food
and ultimately into the cells of the body.
他說我們不應該,以塑膠容器裝食物,用微波爐來加熱。此法則也適用於含脂肪的食物,他說脂肪、高熱與塑膠之綜合,會釋出戴奧辛進入食物中,最後則進入人體細胞內。
8.Instead, he recommends using glass, Corning Ware or ceramic containers for heating food. You get the same results, only without the dioxin.
So such things as TV dinners, instant ramen and soups, etc., should be
removed from the container and heated in something else.  Paper isnt bad
but you dont know what is in the paper. Its just safer to use tempered
glass, Corning Ware, etc.
他建議給食物加熱時,要用玻璃、康寧鍋或陶瓷容器來裝。你得到的結果是一樣的,只是沒了戴奧辛。所以類似電視速食餐、生力麵、速食湯等,需將內容物取出,放入其它容器,再行加熱。紙器並不壞,但是你也不知道,其中含有什麼。使用處理過的玻璃、康寧鍋等,還是安全一些。
9.He reminded us that a while ago some of the fast food restaurants moved away from the foam containers to paper. The dioxin problem is one of the reasons.
他提醒我們,不久前速食快餐店,停用塑料發泡容器改用紙器。戴奧辛問題,即為其中原因之一。
10.Also, he pointed out that Saran wrap is just as dangerous when placed over
foods to be cooked in the microwave. As the food is nuked, the high heat
causes poisonous toxins to actually melt out of the plastic wrap and drip
into the food.
此外,他指出塑膠膜若包裹食物放入微波爐中烹煮,也是同業的危害。由於食物是裸露的,高熱會讓有毒性的戴奧辛,自塑料包裹膜中熔出,而滴入食物。
11.Cover food with a paper towel instead.
代用法是用紙巾覆蓋食物。
12.I believe you should forward to your family and friends--anyone who is
important in your life!
我相信你會將此訊息,傳給你的家人與朋友…任何你生命中重要的人 。
31
發表於 2006-8-11 09:02:44 | 顯示全部樓層
微波爐有害
[微波爐有害]
摘錄自 "疾病的形成與防範" 一書,作者為 洪山本 博士 (新加坡營養學博士)
首先令我們好奇的是何以微波爐有害? 倘若有害,為什麼政府不回收呢 ?
有個很有意思的比喻,或者可比擬這個情況,當你將一隻青蛙放上一個開著大火的熱鍋時,牠會立刻跳走,但如果你用一根蠟燭慢慢燃燒加溫,剛開始時,青蛙並不
覺得有任何燙感,但逐漸的等到牠覺得熱了,想跳走時牠的腳已被熱鍋黏住了,再也無法跳走。
如今微波爐就像那根蠟燭,使用它的人就像那隻青蛙,什麼時候會被黏住,或許是十或二十年之後, 但遲早有可能被黏住。
在醫院中輸血,需將從冰箱拿出的血加以溫熱才可輸入人體,曾有護士為了急救病人節省時間,使用微波爐加溫血液,一輸入體後病人立即死亡以後醫院中嚴格規定
,絕不可用微波爐去溫熱血液。
而專門調製給嬰兒服用的奶粉,盒上說明文字,明白寫出絕不可用微波爐去煮熱,因為它會破壞所有的營養。
有關微波爐所引起的各式傷害,蘇聯人作了許多研究,例如:
(a) 肉類用微波爐加熱後,會產生一種致癌物質,叫 d-NitroSodienthanolanines。
(b) 使用微波爐處理過的牛奶、水果、麥片、會將其中的氨基酸轉化為致癌物。
(c) 蔬菜在用處理後,會將植物生物鹼 (Plant Alkaloids) 轉化成致癌物。
在蘇聯、德國、瑞士等國家,對微波爐造成人體傷害方面,作了許多研究。
有人問,如果微波爐有害,何以政府不制止它的使用?
乃因它所造成的傷害,不是短時間內立即可看到可能是在二十年以後才顯現出來,除非有專業研究員,在實驗室作實驗來證實。
而在美國,一切研究以利益為前導,對無利可圖的事,是沒有人去作研究的。
這個國家以科學掛帥,最優秀的人才都做了工程師,只講究效率、效果,卻不去管後果。
在美國癌症也比其他國家領先,高居第一位。
為保護大眾利益作研究的團體幾乎沒有,都是為大公司牟利而研究。
比較上,在英國社會學系都是最優秀的精英分子,稍次者才去當工程師,由於當政者資歷背景的差異,在美國為公眾利益而不求牟利的研究是無法和其他一些國家比
擬的。
根據蘇聯、德國、瑞士等國家所作對對微波爐的研究,發現有許多負面的結論:
(01) 它破壞腦組織腦的傳播是靠磁波,微波爐處理過的食物,如長期食用,會中和腦磁波,使腦退化,磁波短路,此為長期副作用
(02) 微波爐食物,除了有致癌物之外,它還產生一堆不能為身體所吸收利用的不知名副產品
(03) 長期食用微波爐食物,使男女荷爾蒙分泌量減低或改變。
(04) 微波爐食物的副產品,是長期而永久性的殘存於人體內。
(05) 食物中的礦物質,唯生素及營養大量減少,或改變成致癌物,以及許多不能為身體所分解的合成物。
(06) 微波爐烹煮的食物,使蔬菜中的礦物質,改變成會破壞人體的自由基。
(07) 微波爐食物能引起胃癌,有些胃癌及腸癌,皆與吃太多微波爐食物有關,這或許解釋了何以美國人近些年來,患直腸癌的比例如此迅速增加。
(08) 長期吃微波爐食物,易使身體產生大量癌細胞。
(09) 長期攝取微波爐食物,由於其中營養已被破壞,將使身體免疫系統出問題。
(10) 這樣的食物,終將使記憶退化,精神不集中,情緒不穩定,且理解力降低。
GMT+8, 2026-10-20 00:26 , Processed in 0.049850 second(s), 19 queries .
